Altair RISE
Nominate Yourself Now!
Cannot run RapidMiner process from Python with Performance Operator
User: "winn"
New Altair Community Member
Updated by Jocelyn
I am trying to run a RapidMiner process using a Python script. When I run the process ( Decision Tree Model) without Performance operator, I am able to successfully execute it via connector.run_process but when I add Performance operator, the Python script fails with the error:
 raise ValueError("Cannot handle files with '" + str(extension) + "' extension.")
ValueError: Cannot handle files with '.ioo' extension.
I am attaching my process rmp files without Performance operator and with performance operator.
I am executing following code in python:
<p>connector = rapidminer.Studio(rm_home, rm_stdout=None, override_python_binary=True)</p><p><span style="background-color: transparent; color: inherit; font-size: inherit; font-family: "open sans", sans-serif;">my_process = connector.run_process("//Local Repository/processes/MyProcess")</span><br></p>
1 - 3 of 31
    User: "hbajpai"
    Accepted Answer
    Hey @winn,
    The error is because you are passing the performance .ioo output as an object to Python and it is unable to parse it. If you use Performance to Data operator, after your performance block to convert the output to an example set, the error can be resolved. This way the pandas will parse the example set as a dataframe.
    User: "winn"
    OP
    Hey @hbajpai
    Thanks a lot, this resolved my issue. For the future, how can I check what is the output type from an operator? I couldn't find that performance operator returns .ioo output.
    User: "hbajpai"
    Accepted Answer
    @winnYou can check the metadata by hovering over the output port of the operator to have an idea.
