🎉Community Raffle - Win $25
Join and Win
Logistic regression
User: "tonyboy9"
Altair Community Member
Updated by Jocelyn
Where is logistic regression located within Operators?
1 - 3 of 31
    User: "varunm1"
    New Altair Community Member
    Accepted Answer
    Updated by varunm1
    Hello @tonyboy9
    The operators can be searched in the operator window search bar. The logistic regression is present in Modeling --> Predictive --> Logistic Regression folder.
    User: "tonyboy9"
    OP
    Okay, Varun, I did locate logistic regression. I'm a newbie from Data Science A-Z on line. I'm familiar with gretl statistical software, building models using logistic regression. I stumbled upon Rapid Miner while searching for the best data mining software. I'm beginning at https://www.youtube.com/watch?v=Gg01mmR3j-g&list=PLssWC2d9JhOZLbQNZ80uOxLypglgWqbJA Getting Started With Rapid Miner. I have a data set called creditriskdata loaded in the Repository. My goal is to build a model using logistic regression which will tell me which borrower attributes are most likely to lead to default. My plan is to take my data set through each of the getting started videos and learn what works. Do you think that is good strategy? Thank you for your time. Tony
    User: "varunm1"
    Accepted Answer
    Hello @tonyboy9
    Good to hear that you started using Rapidminer. You can also go through academy.rapidminer.com for tutorials as well.
    You can try many different things and learn a lot using Rapidminer. We are also happy to help and this is a great community.
