🎉Community Raffle - Win $25
Join and Win
How can the Generate Data operator be configured to create right or left skewed distributions?
User: "michaelgloven"
New Altair Community Member
Updated by Jocelyn
How can the Generate Data operator be configured to create right or left skewed distributions? I see the normal distribution and would like to adjust this for skew and well as trimming negative tails.
1 - 3 of 31
    i think you cannot. What kind of distribution would you need?
    Best,
    Martin
    OP
    Hi Martin, we've created a Monte Carlo process in RM and have been able to successfully apply a single gaussian cluster to input data to our function. However, some of the input data by it's nature is a right or left skew distribution and\or must be non-negative. The practical use case is this - when we calculate the maximum burst pressure of steel pipe using a specified pipe property from the mill (let's say 60,000 psi), it is very unlikely the specified property is an average. The 60,000 psi more often represents maybe 2-3 standard deviations to the left and the actual average is probably 68,000 psi with a small tail to the right capped at some maximum like 70,000 psi. So, we're trying to figure out how to shape a normal distribution with an understanding what our tails look like. I found ways to do this on stack exchange but the math requires calculus (which I don't know how to do easily in RapidMiner), and we're not trying to get an exact solution, just something that better represents reality.
    User: "MartinLiebig"
    Altair Employee
    Accepted Answer
    Hey,
    i think i got something for you which i am writing for another client. This may be quickly extendable to cover your need.
    I will connect with you via e-mail.
    Cheers,
    Martin
