🎉Community Raffle - Win $25
Join and Win
on RM Server 9.5 -
User: "deepeshj"
New Altair Community Member
Updated by Jocelyn
Using RM Server 9.5. When I send a test email in System Settings, it works fine. When I use the Send Mail operator in a process run on the server, it does not work.
I tried to use the solution provided in thread https://community.rapidminer.com/discussion/45329/on-server-send-test-email-works-using-send-mail-operator-does-not
but not able to locate the path mentioned. I saw that the admin marked the problem as resolved and closed too, but it doesn't seem to be case.
1 - 2 of 21
    @deepeshj you can now create a new connection, like the ones your create for DB, Twitter or other sources, on the server for your email settings and then you can use that on the send mail operator.
    User: "deepeshj"
    OP
    @MarcoBarradas thanks for the revert. I had version 9.3 of RM Studio, hence did not have that option to set up an email connection. Updated to version 9.5 and now its working.
    Thank you :)
