Using RM Server 9.5. When I send a test email in System Settings, it works fine. When I use the Send Mail operator in a process run on the server, it does not work.
I tried to use the solution provided in thread https://community.rapidminer.com/discussion/45329/on-server-send-test-email-works-using-send-mail-operator-does-not
but not able to locate the path mentioned. I saw that the admin marked the problem as resolved and closed too, but it doesn't seem to be case.
