🎉Community Raffle - Win $25
Join and Win
How to change regular attribute by appending macro and use that attribute for calculation
User: "sgnarkhede2016"
New Altair Community Member
Updated by Jocelyn
Hello,
I have the regular attribute name  "atttribute_W" , the W is coming from my macro and append to  atttribute
next time regular attribute changes to "atttribute_Y" as per my config macro
When I am using this in generate attribute for calculation I getting error "erroneous expression"
Value_%{macro1}                if (Profile=="High",attribute_%{maco1}*100,
                                             if (Profile=="Medium",attribute_%{maco1}*200,
                                             attribute_%{maco1}*300))
1 - 4 of 41
    User: "varunm1"
    Hello @sgnarkhede2016
    Can you provide your process as .rmp file? You can export from rapidminer using File --> Export process and attach it here. Also, did you check if macro names are correct?
    Hi @sgnarkhede2016 if you what to use the value of the macro you need to use eval(%macro_name) and you'll also need to use concatenate if you expect to have macro=10 to obtain attribute_10
    OP
    Updated by sgnarkhede2016
    It works only for the attribute name "check_%{initial}"  but when used in expression it won't work.
    check_%{initial}   score_%{initial}
    e.g.
    score_%{initial} is already calculated in example set i want to calculate the score on that value but %{initial} changes to W, M,HY(week,Month..) as per iteration.
    I tried Concat but it not working for me
    OP
    Accepted Answer
    Its work for me before I did not use quotes for attributes names that's why not working
    round(eval("AARPI_TXN_SD_CNT_"+%{initial}))
