100,000 rows of data limit with an Educational license.
User: "MarlaBot"
New Altair Community Member
Updated by Jocelyn
A RapidMiner user wants to know the answer to this question: "Trying to apply an operator, I am receiving an error message, which I attached below. I manually entered a valid Educational license and restarted RapidMiner, then tried re-installing it, nothing seems to help. Any idea how to fix this? Thank you."
1 - 6 of 61
    User: "David_A"
    Hi,
    the screen shot shows, that he is still using a commercial "Small" license.
    Please check in the ,/RapidMiner/licenses/rapidminer-studio folder and remove the small license there. Probably the commercial license has a higher priority than the educational.
    Best,
    David
    User: "p15248633"
    It worked thanks
    User: "campos_10127"
    Hi!
    I have a student license, however I cannot load a database of more than 10,000 lines. How can I increase the processing capacity? Thanks!
    User: "varunm1"
    Hello @campos_10127
    Can you go to Settings --> Manage licenses and see if you have Educational license under your active licenses? If not, then you need to click on "Sync licenses" option and log in to your rapidminer account (student account) that you created.
    User: "Jasmine_"
    Hi @campos_10127,
    I just checked your licenses and it looks like you've only ever had a free and trial license for RapidMiner Studio. Since I can tell that you are a student from your email address, I have generated an educational license for you. Next time you use RM Studio, you should be able to use as many rows as you want. If you still aren't able to, you can view the instructions on this page for how to manually install a license key: https://docs.rapidminer.com/latest/studio/installation/license-install.html. Please message me privately if you have any other questions. I hope this helps!
    Kind regards,
    Jasmine
    Hello! Thanks a lot for the help! It's working!
