Where to write the solution Code
User: "asiddiq"
New Altair Community Member
Updated by Jocelyn
I have a lot of questions, and when I search for a solution I find some answers that could be done using codes such as the following; However, my question is where should I write this code to solve the problem!?
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<process version="5.3.008">
  <context>
    <input/>
    <output/>
    <macros/>
  </context>
  <operator activated="true" class="process" compatibility="5.3.008" expanded="true" name="Process">
    <process expanded="true">
      <operator activated="true" class="retrieve" compatibility="5.3.008" expanded="true" height="60" name="Retrieve Iris" width="90" x="45" y="30">
        <parameter key="repository_entry" value="//Samples/data/Iris"/>
      </operator>
      <operator activated="true" class="hierarchical_multi_class_classification" compatibility="5.3.008" expanded="true" height="76" name="Hierarchical Classification" width="90" x="179" y="30">
        <list key="hierarchy">
          <parameter key="versicolor_virginica" value="Iris-versicolor"/>
          <parameter key="versicolor_virginica" value="Iris-virginica"/>
          <parameter key="root" value="Iris-setosa"/>
          <parameter key="root" value="versicolor_virginica"/>
        </list>
          <operator activated="true" class="support_vector_machine" compatibility="5.3.008" expanded="true" height="112" name="SVM" width="90" x="179" y="30"/>
          <connect from_port="training set" to_op="SVM" to_port="training set"/>
          <connect from_op="SVM" from_port="model" to_port="model"/>
          <portSpacing port="source_training set" spacing="0"/>
          <portSpacing port="sink_model" spacing="0"/>
        </process>
      </operator>
      <connect from_op="Retrieve Iris" from_port="output" to_op="Hierarchical Classification" to_port="training set"/>
      <connect from_op="Hierarchical Classification" from_port="model" to_port="result 2"/>
      <connect from_op="Hierarchical Classification" from_port="example set" to_port="result 1"/>
      <portSpacing port="sink_result 3" spacing="0"/>
    </process>
  </operator>
</process>
1 - 1 of 11
    User: "rfuentealba"
    Accepted Answer
    Hello,
    That is not "code to be written somewhere" but rather "the source code of a process".
    Do the following:
    1. Save your RapidMiner process.
    2. Go to View > Show Panel > XML.
    3. Place your new panel in a position that makes it comfortable to use.
    4. Copy the content you want to use.
    5. Click the green button to check it's going OK.
    6. Go back to the Process view and it will show you the entire process.
    7. Now you have to analyse it so that you get your answers.
    Sharing the XML is easier than exporting, saving and uploading a RapidMiner process file, but there is nothing special on that. Hope this helps.
    All the best,
    Rodrigo.
