I have a lot of questions, and when I search for a solution I find some answers that could be done using codes such as the following; However, my question is where should I write this code to solve the problem!?
<process version="5.3.008">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.3.008" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="retrieve" compatibility="5.3.008" expanded="true" height="60" name="Retrieve Iris" width="90" x="45" y="30">
<parameter key="repository_entry" value="//Samples/data/Iris"/>
<operator activated="true" class="hierarchical_multi_class_classification" compatibility="5.3.008" expanded="true" height="76" name="Hierarchical Classification" width="90" x="179" y="30">
<list key="hierarchy">
<parameter key="versicolor_virginica" value="Iris-versicolor"/>
<parameter key="versicolor_virginica" value="Iris-virginica"/>
<parameter key="root" value="Iris-setosa"/>
<parameter key="root" value="versicolor_virginica"/>
</list>
<operator activated="true" class="support_vector_machine" compatibility="5.3.008" expanded="true" height="112" name="SVM" width="90" x="179" y="30"/>
<connect from_port="training set" to_op="SVM" to_port="training set"/>
<connect from_op="SVM" from_port="model" to_port="model"/>
<portSpacing port="source_training set" spacing="0"/>
</process>
<connect from_op="Retrieve Iris" from_port="output" to_op="Hierarchical Classification" to_port="training set"/>
<connect from_op="Hierarchical Classification" from_port="model" to_port="result 2"/>
<connect from_op="Hierarchical Classification" from_port="example set" to_port="result 1"/>
</process>
</process>
