I cannot seem to download rapidMiner server.
figs
figs New Altair Community Member
edited November 2024 in Community Q&A
I have manged to create a new environment variable named JAVA_HOME - see attached. However when I try to launch the rapidMiner installation file the cmd window appears for second and disappears.
Welcome!
Answers
  • aschaferdiek
    aschaferdiek New Altair Community Member
    Hi! Could you please start the installer within this terminal window you already have open? With this we probably have more information about what failed.
  • figs
    How do I start the installer in the terminal window?
  • aschaferdiek
    There are multiple ways to achieve this. You probably need to go into the containing directory first. Open a terminal window, then use "cd <the-directory>" and afterwards type "rapidminer-server-installer.bat" and press ENTER. For more information on how to navigate to the directory and to run it check out the section "Command prompt" here: https://www.computerhope.com/issues/ch001668.htm
  • figs
    C:\Users\ferga.LAPTOP-AER3Q2L6\Downloads\rapidminer-server-installer-9.6.0\rapidminer-server-installer-9.6.0\bin
    This is where the installer files lives in my system. How do I install via the terminal in windows 10?
  • figs
    I pasted in the file path in cmd. See attached.
    cmd.JPG 91.1K
  • Marco_Barradas
    Marco_Barradas
    Altair Employee
    @figs you just need to set the path of the file con the command line.
    You don't need the install command
    son just paste on you command promt
    C:\Users\ferga.LAPTOP-AER3Q2L6\Downloads\rapidminer-server-installer-9.6.0\rapidminer-server-installer-9.6.0\bin\rapidminer-server-installer.bat
    An that should start your installer.
  • figs
    This is what I'am getting now!
  • aschaferdiek
    It seems that your JAVA_HOME environment variable is pointing to an invalid directory. The JAVA_HOME variable has to point to a directory which contains a bin/ directory. Please check if that's the case.
    The reason why the installer is not falling back to your normal PATH binary (you used java -v in another thread) is that JAVA_HOME is prioritized for the bat installer file. I think preferably you should set the correct JAVA_HOME or unset it and just use the java binary from path.
  • figs
    How do I use java binary from path?
  • aschaferdiek
    edited April 2020
    There are two possible options where the java binary is derived from: 1. PATH environment variable or 2. JAVA_HOME environment variable. JAVA_HOME is preferred even though PATH should already be set (that's why java -version worked on your machine). To just use the PATH option you need to remove the JAVA_HOME environment variable. Please follow instructions on the Internet on how to add, edit or remove binaries from PATH or how to manage environment variables in Windows.
    Nevertheless I would personally make sure why the JAVA_HOME option failed for you in the first place. Do so by checking if your Java is installed properly, if there's a bin/ sub-folder in the given JAVA_HOME path you've set and shown above.
Welcome!
Welcome!
