1 - 9 of
91
@lionelderkrikor- sorry Under company policy it cant be shared. had you observed this anytime before.
@lionelderkrikor - can we connect via any application i can show the glitch.
@pallav,
Yes we can connect via an application. Do you think to a particular application?
Regards,
Lionel
Regards,
Lionel
@lionelderkrikor No i mean if you can send me any link where i can connect with you like webexx or skype. My email id is pallav.kumar@in.imshealth.com
Hi @pallav ,
are there time zone things going on? keep in mind that RM operators are using SYSTEM as default time zone. That can sometimes do tricky things with time filters.
Cheers,
Martin
@mschmitz - My rapid Miner studio is installed My local system but rapid miner server is hosted on Us cluster so there will be time difference between those two, but how does it make difference because when i running process through server it is running on Us cluster only right .
1 - 1 of
11
Hi,
that can be an issue. Keep in mind, that if you filter for Date > 9AM local time filters on different times if you run it on different time zoned servers.
Best,
Martin
In deed, interesting ...!!!
Can you share your process and your data in order we can reproduce what you observe.
Regards,
Lionel
