Altair RISE
Nominate Yourself Now!
Formating an output table
User: "achint_kumar"
New Altair Community Member
Updated by Jocelyn
Hi Everyone,
I have processed a summary table using RM. I need the below formatting:
1) to convert my FIRST ROW in attached data to COLUMN HEADER.
2) To convert "id" to an actual column and arrange it in first row of excel as it currently write in the end column of an excel.
To be converted into below output excel:
Looking forward to hearing from you. :)
1 - 4 of 41
    User: "[Deleted User]"
    Updated by [Deleted User]
    @achint_kumar
    Hello
    Could you please send your data?  :)
    Thank you
    mbs
    OP
    Updated by achint_kumar
    I'm not able to attach the file, maybe because i'm using office laptop, is it possible for you to make a dummy data like that & get the solution? Looking forward to hearing from you.
    User: "varunm1"
    Accepted Answer
    Updated by varunm1
    Hello @achint_kumar
    You need to use the "Rename by example value" operator to set the first row in row number option as your column header.
    For question 2, I guess try removing the special role of this column using "set role" operator and selecting regular as the type for id column. Then try using the "reorder attributes" operator to order the attributes as you wish and then use write excel operator..
    OP
    @mbs
    Thank you it works very well. :)
