🎉Community Raffle - Win $25
Join and Win
X-Cobweb problem
User: "Lisi"
New Altair Community Member
Updated by Jocelyn
Hi,
Can somebody help to understand why the X-Cobweb algorithm won´t work just like it does in Weka? I´m trying to cluster the classic zoo.arff data set. In Weka works fine but in RapidMiner it shows each instance in a separate cluster.
Thanks in advance
1 - 3 of 31
    User: "MPB_"
    Hey @Lisi ,
    could you please share the process or at least the parameters which are set for the clustering?
    User: "Lisi"
    OP
    Hi. Yes, of course.
    The process consist of a readArff Operator (which reads the file zoo.arff) and the output port of this operator connects to a W-Cobweb Operator with the Following parameters:
    - A: 1.0
    - C: 0.0028
    - S: 4.2
    This last operator uses both outputs and connect them to res.
    I attach the output from RapidMiner and what I get from Weka.
    User: "[Deleted User]"
    Updated by [Deleted User]
    @Lisi
    Hello
    Did you check some settings in weka and rapidminer?( I mean that both of them in the setting of process should be the same. Most of the time people forget to check them.) :)
    So please check all options of process in both software then if you see the problem again send your process and data in order we can check it again. ;)
    Thank you
    mbs
