🎉Community Raffle - Win $25
Join and Win
Am I cannot use
User: "YB_Choi"
New Altair Community Member
Updated by Jocelyn
Hello, I'm newbie & using Rapidminer Studio 9.6 version.
(Sorry to my poor english.)
I did download titanic data set from Kaggle.com, and analyzed it with Rapidminer.
There were no problem when I using the data which stored in my local drive.
Then I uploaded the same data into AWS S3 and imported it.
I used "Read Amazon S3" and "Read CSV". "Read CSV" showed me right result, but "Select Attributes" displayed nothing.
*refer the attached picture please.
 - In A (local drive file), Select Attributes displayed the lists ~ Age, Cabin, Embarked, .....
 - But B (AWS S3), Select Attributes displayed nothing in dialog box.
   There is no security or access problem. When I directly connected the "Read CSV"'s out port with result,
   it displayed right output.
   PS. Perhaps, Don't mind the yellow warning icon in the "Read Amazon S3". That's only because I'm not
        accessed to AWS now.
Am I cannot use "Select Attributes" with Amazon S3 file?
or I did some mistake?
Thank you.
1 - 6 of 61
    User: "varunm1"
    Updated by varunm1
    Hello @YB_Choi
    You can use it. I guess its not pre-fetching attribute names to be displayed in Select attributes operator. Can you set a breakpoint before Select Attribute operator? This can be done by right-clicking on select attributes and then select "breakpoint before". Once you do this, run the process to see if it is displaying the data. If this is displaying data, then it fine, you just need to add the attribute names manually in "Selected Attributes" section and press the PLUS symbol.
    User: "YB_Choi"
    OP
    Thank you, varunm.
    I cannot understand the "add the attribute names manually in "Selected Attributes" section and press the PLUS symbol."
    Can you explain it more detail, please?
    fig1. Read CSV from S3 is success
    fig2. but Select Attributes display nothing
    User: "YB_Choi"
    OP
    Sorry, I got it.
    Press the green + button & type the column names manually!!
    (Oh my gosh. Real manually??)
    Thank you very much.
    User: "varunm1"
    Accepted Answer
    Updated by varunm1
    @YB_Choi
    In general, rapidminer will propagate metadata information (ATtribute names etc.) when we use most of the operators. This is enabled by selecting PROCESS --> VALIDATE AUTOMATICALLY. Sometimes it cannot, I think this is one of those cases. I am tagging @David_A and @mschmitz if they have any information for you.
    User: "David_A"
    as Varun has pointed out, normally RapidMiner will propagate the meta-data and then will know the attribute names, so you can for example add them more simply to the attribute selection.
    In your case the data are picked from a remote S3 bucket, so until the process is running, there is no chance to know the layout of the data. What you can do (if the data in the S3 bucket are not changing regularly), is simply run the first part of the process, store the result of the Read CSV operator in your RapidMiner repository and retrieve them in another process for further work. Then you also have the full meta data and the more convenient user interface.
    Best,
    David
    User: "YB_Choi"
    OP
    Updated by YB_Choi
    David_A
    Now I'm doing that. ^^  Thank you.
