Defining 2D shell contacts
Hung
Hung Altair Community Member
edited September 2023 in Community Q&A
Hi,
I am trying to define a shell contact between a circle and a rectangle in a 2D problem, as shown in the picture.
However, the result showed no contact between the circle and the rectangle.
I don't know what steps I am missing. My expected result will be like this
I would like to attach my hm file.
Thanks,
Hung
Answers
  • Kranzeder
    Kranzeder
    Altair Employee
    Hi Hung
    Optistruct doese not provide Edge2Edge contacts.
    I would suggest to use CGAP(G) elements with matching node to node mesh.
    I have attached an example where this kind of modelling is used.
    Hint: In case models are symmetric it is a general recommendation to work with half, symmetric model only.
  • Hung
    Hi Hung
    Hi Juergen Kranzeder,
    Thank you for sharing. The reason I want to create contact is to constrain contact force or contact pressure in the Topology Optimization process.
Welcome!
Welcome!
