Logic question
User: "pb42"
New Altair Community Member
Updated by Jocelyn
I have a list of grades, and I want to create an attribute that tells me which examples contain a D, F, or W grade (i.e., Y, N). Is there a logic statement that would allow me to do this in the Generate Attribute operator, or is there another operator that would help me to do this?
1 - 3 of 31
    User: "varunm1"
    Accepted Answer
    Updated by varunm1
    Hello @pb42
    You can use generate attributes operator and write a simple if statement. I added a sample .rmp file in this with generate attribute, I used the Titanic dataset where I generated a new attribute named "Class" that will have value "Y" if a passenger belongs to either First or second class and "N" for other classes (Passenger Class attribute).
    if(([Passenger Class] == ("First") || [Passenger Class] == ("Second")), "Y", "N")
    You can do it similarly for your case. To open the .rmp file in your studio, you can download from here and in studio go to  FILE --> Import Process and navigate to the .rmp file downloaded.
    Please let us know if this helps you. If you need more, please inform us.
    User: "varunm1"
    Updated by varunm1
    NA
    User: "pb42"
    OP
    Thank you. This worked perfectly.
