1 - 7 of
71
Hi,
this should be somewhat related to deep learning extension. Can you temporarly delete this and check if it works?
Best,
Martin
CC @pschlunder
Hi @btibert,
in your .Rapidminer folder (/home/btilbert/.RapidMiner) you have a folder called extensions. Somewhere there is the deep learning jar (maybe under managed?). Just delete/copy/put it somewhere else and restart studio.
Cheers,
Martin
Cheers,
Martin
hi @btibert yes there are numerous bugs with the DL extension. That's why it is in beta
We try to keep the Product Feedback page (i.e. bugs) up-to-date as best as we can: https://community.rapidminer.com/categories/product-feedback
That said, Version 0.9.3 was just released this week so please check this and post new bug reports if you find them.
Thanks.
Thanks.
Scott
Thanks @sgenzer that did the trick (updating the DL extension). And thanks for the note on the product feedback area!
Hi @btibert,
glad to hear the update solved your problem. Very likely it was caused due to an incompatibility with macOS Catalina. This was fixed in version 0.9.3. Sorry for the inconvenience.
Please note, that due to a general movement in the market away from providing GPU drivers for Deep Learning libraries on macOS, we also had to drop this support. Hence on macOS we can only support Deep Learning executions on CPU. But still you can build and test your processes on your mac and push them to a RapidMiner Server with GPUs available and make use of them, there.
1 - 1 of
11
Thanks.
Thanks.
Scott
