🎉Community Raffle - Win $25
Join and Win
Executing the standalone.sh file
User: "boterax"
New Altair Community Member
Updated by Jocelyn
I'm done going through all the steps of the Starter and the last message enquires me to execute the standalone.sh in the bin folder.
Does any of you know how to execute it? when I open it, it's just a text file and I do not know how to do...
Thank you for your help ;)
1 - 10 of 101
    User: "YYH"
    Altair Employee
    Accepted Answer
    Updated by YYH
    User: "sgenzer"
    Altair Employee
    yes assuming you're on Unix/Linux/Mac, just run ./standalone.sh
    User: "boterax"
    OP
    I ran the sh file in the terminal, it stops at one point saying "Scheduler was started successfully" but nothing else happens. What else should i do ?
    Thank you
    User: "sgenzer"
    Altair Employee
    @boterax I assume you're following the steps on this page? https://docs.rapidminer.com/latest/server/install/
    Have you gotten here?
    User: "boterax"
    OP
    yes, i'm following these steps. but i can't get access to the web interface... they say the website is not accessible...
    User: "sgenzer"
    Altair Employee
    can you pls share the output (probably easiest as a text file). I will promote your rank so you can attach files.
    User: "boterax"
    OP
    << 16:43:08,304 INFO  [org.quartz.core.QuartzScheduler] (taskScheduler-1) Scheduler ProcessScheduler_$_NON_CLUSTERED started.
    16:43:08,305 INFO  [stdout] (taskScheduler-1) 2020-02-21 16:43:08.305  INFO 4297 --- [taskScheduler-1] c.r.e.s.service.task.StartSchedulerTask  : Scheduler was started successfully
    17:12:46,463 INFO  [com.rapidminer.server.server.license.LicenseEJB] (EJB default - 9) Reloading licenses. >>
    That's what i got from the terminal
    User: "sgenzer"
    Altair Employee
    there should be a LOT more than that
    User: "boterax"
    OP
    i only posted the end message, do you need the whole text from the terminal ?
    User: "boterax"
    OP
    it seems i cant upload txtfile
