Altair RISE
Nominate Yourself Now!
model deployment
User: "Thiru"
New Altair Community Member
Updated by Jocelyn
Is it possible to load the unlabelled fresh field data set to check the already build
model in rapidminer.  If so, can I have the link of blocks to implement. thank you.
regds
thiru
1 - 2 of 21
    User: "varunm1"
    Hello @Thiru
    If I understand it correctly, you are trying to use a trained model to predict a new dataset. Yes, it can be done. You need to store thre trained model using "Store" operator in Repository and then you can drag it and drop it in a process window and connect the Trained model and New dataset to "apply model operator. There is also an option for model deployment in automodel.
    https://docs.rapidminer.com/latest/studio/guided/deployments/
    User: "Thiru"
    OP
    yes.   The trained model will be supervised eg. Knn.     New data set to be tested will be  with unlabelled target attribute.   can I?
