full process flow
User: "Thiru"
New Altair Community Member
Updated by Jocelyn
can I have a some link to full process flow for a supervisory algorithm
let say: KNN .  I see like this:
load data (ETL with subprocess ) -> multiply->cross validation of sub process of training & testing using KNN model -> next (??)
should we use same process for all other algorithms?
1 - 4 of 41
    User: "sgenzer"
    Altair Employee
    hi @Thiru I would suggest starting with one of the templates that are on the RapidMiner Studio splash screen:
    Scott
    User: "varunm1"
    Hello @Thiru
    Not a requirement but to keep things simple you can use multiple cross-validations with different algorithms in the same process. This is based on your comfort. Also, rapidminer doesn't open multiple process windows at a time, if you want to check other processes then your current process will be closed.
    Hope this helps.
    User: "Thiru"
    OP
    thanks for your reply.  I will check
    Hi @Thiru,
    this may be helpful for you: https://www.youtube.com/watch?v=dKp8oFSwIYs
    Best,
    Martin
