1 - 4 of
41
Hello @Thiru
Hope this helps.
should we use same process for all other algorithms?
Not a requirement but to keep things simple you can use multiple cross-validations with different algorithms in the same process. This is based on your comfort. Also, rapidminer doesn't open multiple process windows at a time, if you want to check other processes then your current process will be closed.Hope this helps.
Scott
