Cannot Start Rapid Miner Server Service
John_Mac
John_Mac New Altair Community Member
edited November 2024 in Community Q&A
Hello,
I was hoping someone on here can possibly help.  I have installed Rapid Miner Server 9.4.1 on an Azure VM running Windows 10.  I can run it using standalone.bat but when I try to run the service it gives a non-specific error and does not start.
Has anyone seen this behavior before?  I did a lot of troubleshooting but cannot seem to come up with a solution.
Thanks!
Welcome!
Best Answer
  • mmichel
    mmichel New Altair Community Member
    Answer ✓
    Hi,
    have you checked the server.log file? Is there anything logged while starting the service?
    If it's not the case the service boot-up might be blocked by the '.r.lock' file (note the dot at the beginning of the name). Please verify if this file does not exist within the $install-dir/bin directory before starting the service - otherwise delete it.
    Cheers
    Marcel
Answers
  • sgenzer
    sgenzer
    Altair Employee
  • mmichel
    Answer ✓
    Hi,
    Cheers
    Marcel
  • John_Mac
    edited January 2020
    Thank you sooo much Marcel.  I did have the .r.lock file in there.  After removing that the server is now up and running.
    Appreciate the help.
Welcome!
Welcome!
