<?xml version="1.0" encoding="UTF-8"?><process version="9.5.001"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="9.5.001" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="-1"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="false" class="retrieve" compatibility="9.5.001" expanded="true" height="68" name="Retrieve Twitter" width="90" x="45" y="85"> <parameter key="repository_entry" value="//Local Repository/Connections/Twitter"/> </operator> <operator activated="false" class="social_media:search_twitter" compatibility="9.3.000" expanded="true" height="82" name="Search Twitter" width="90" x="179" y="85"> <parameter key="connection_source" value="repository"/> <parameter key="query" value="Australian Bushfires"/> <parameter key="result_type" value="recent or popular"/> <parameter key="limit" value="100"/> <parameter key="filter_by_geo_location" value="false"/> <parameter key="radius_unit" value="miles"/> </operator> <operator activated="true" class="retrieve" compatibility="9.5.001" expanded="true" height="68" name="Retrieve Twitter for Gary - search results" width="90" x="45" y="289"> <parameter key="repository_entry" value="Twitter for Gary - search results"/> </operator> <operator activated="true" class="multiply" compatibility="9.5.001" expanded="true" height="124" name="Multiply" width="90" x="313" y="187"/> <operator activated="true" class="subprocess" compatibility="9.5.001" expanded="true" height="82" name="Subprocess (2)" width="90" x="514" y="493"> <process expanded="true"> <operator activated="true" class="nominal_to_text" compatibility="9.5.001" expanded="true" height="82" name="Nominal to Text" width="90" x="45" y="34"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="Text"/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="nominal"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="file_path"/> <parameter key="block_type" value="single_value"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="single_value"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> </operator> <operator activated="true" class="text:process_document_from_data" compatibility="8.2.000" expanded="true" height="82" name="Process Documents from Data" width="90" x="179" y="34"> <parameter key="create_word_vector" value="true"/> <parameter key="vector_creation" value="Binary Term Occurrences"/> <parameter key="add_meta_information" value="false"/> <parameter key="keep_text" value="false"/> <parameter key="prune_method" value="percentual"/> <parameter key="prune_below_percent" value="3.0"/> <parameter key="prune_above_percent" value="30.0"/> <parameter key="prune_below_rank" value="0.05"/> <parameter key="prune_above_rank" value="0.95"/> <parameter key="datamanagement" value="double_sparse_array"/> <parameter key="data_management" value="auto"/> <parameter key="select_attributes_and_weights" value="false"/> <list key="specify_weights"/> <process expanded="true"> <operator activated="true" class="text:tokenize" compatibility="8.2.000" expanded="true" height="68" name="Tokenize" width="90" x="45" y="34"> <parameter key="mode" value="non letters"/> <parameter key="characters" value=".:"/> <parameter key="language" value="English"/> <parameter key="max_token_length" value="3"/> </operator> <operator activated="true" class="text:filter_stopwords_english" compatibility="8.2.000" expanded="true" height="68" name="Filter Stopwords (English)" width="90" x="179" y="34"/> <operator activated="true" class="text:filter_by_length" compatibility="8.2.000" expanded="true" height="68" name="Filter Tokens (by Length)" width="90" x="313" y="34"> <parameter key="min_chars" value="4"/> <parameter key="max_chars" value="25"/> </operator> <connect from_port="document" to_op="Tokenize" to_port="document"/> <connect from_op="Tokenize" from_port="document" to_op="Filter Stopwords (English)" to_port="document"/> <connect from_op="Filter Stopwords (English)" from_port="document" to_op="Filter Tokens (by Length)" to_port="document"/> <connect from_op="Filter Tokens (by Length)" from_port="document" to_port="document 1"/> <portSpacing port="source_document" spacing="0"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <operator activated="true" class="text:wordlist_to_data" compatibility="8.2.000" expanded="true" height="82" name="WordList to Data" width="90" x="313" y="34"/> <connect from_port="in 1" to_op="Nominal to Text" to_port="example set input"/> <connect from_op="Nominal to Text" from_port="example set output" to_op="Process Documents from Data" to_port="example set"/> <connect from_op="Process Documents from Data" from_port="word list" to_op="WordList to Data" to_port="word list"/> <connect from_op="WordList to Data" from_port="example set" to_port="out 1"/> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="source_in 2" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> </process> <description align="center" color="transparent" colored="false" width="126">for wordcloud</description> </operator> <operator activated="true" class="operator_toolbox:extract_sentiment" compatibility="2.3.000" expanded="true" height="82" name="Extract Sentiment" width="90" x="514" y="289"> <parameter key="model" value="vader"/> <parameter key="text_attribute" value="Text"/> <parameter key="show_advanced_output" value="false"/> <parameter key="use_default_tokenization_regex" value="true"/> <list key="additional_words"/> </operator> <operator activated="true" class="subprocess" compatibility="9.5.001" expanded="true" height="82" name="Subprocess" width="90" x="514" y="34"> <process expanded="true"> <operator activated="true" class="date_to_nominal" compatibility="9.5.001" expanded="true" height="82" name="Date to Nominal" width="90" x="45" y="34"> <parameter key="attribute_name" value="Created-At"/> <parameter key="date_format" value="MM/dd/yyyy"/> <parameter key="time_zone" value="America/New_York"/> <parameter key="locale" value="English (United States)"/> <parameter key="keep_old_attribute" value="false"/> </operator> <operator activated="true" class="nominal_to_date" compatibility="9.5.001" expanded="true" height="82" name="Nominal to Date" width="90" x="179" y="34"> <parameter key="attribute_name" value="Created-At"/> <parameter key="date_type" value="date"/> <parameter key="date_format" value="MM/dd/yyyy"/> <parameter key="time_zone" value="America/New_York"/> <parameter key="locale" value="English (United States)"/> <parameter key="keep_old_attribute" value="false"/> </operator> <connect from_port="in 1" to_op="Date to Nominal" to_port="example set input"/> <connect from_op="Date to Nominal" from_port="example set output" to_op="Nominal to Date" to_port="example set input"/> <connect from_op="Nominal to Date" from_port="example set output" to_port="out 1"/> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="source_in 2" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> </process> <description align="center" color="transparent" colored="false" width="126">convert &quot;Created-At&quot; to date only</description> </operator> <operator activated="true" class="aggregate" compatibility="9.5.001" expanded="true" height="82" name="Aggregate" width="90" x="648" y="34"> <parameter key="use_default_aggregation" value="false"/> <parameter key="attribute_filter_type" value="all"/> <parameter key="attribute" value=""/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="attribute_value"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="time"/> <parameter key="block_type" value="attribute_block"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_matrix_row_start"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <parameter key="default_aggregation_function" value="average"/> <list key="aggregation_attributes"> <parameter key="Created-At" value="count"/> </list> <parameter key="group_by_attributes" value="Created-At"/> <parameter key="count_all_combinations" value="false"/> <parameter key="only_distinct" value="false"/> <parameter key="ignore_missings" value="true"/> <description align="center" color="transparent" colored="false" width="126">count tweets by date</description> </operator> <connect from_op="Retrieve Twitter" from_port="output" to_op="Search Twitter" to_port="connection"/> <connect from_op="Retrieve Twitter for Gary - search results" from_port="output" to_op="Multiply" to_port="input"/> <connect from_op="Multiply" from_port="output 1" to_op="Subprocess" to_port="in 1"/> <connect from_op="Multiply" from_port="output 2" to_op="Extract Sentiment" to_port="exa"/> <connect from_op="Multiply" from_port="output 3" to_op="Subprocess (2)" to_port="in 1"/> <connect from_op="Subprocess (2)" from_port="out 1" to_port="result 3"/> <connect from_op="Extract Sentiment" from_port="exa" to_port="result 2"/> <connect from_op="Subprocess" from_port="out 1" to_op="Aggregate" to_port="example set input"/> <connect from_op="Aggregate" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="252"/> <portSpacing port="sink_result 3" spacing="126"/> <portSpacing port="sink_result 4" spacing="21"/> <description align="center" color="yellow" colored="false" height="217" resized="true" width="173" x="16" y="14">You will need you use your own Twitter Connection here</description> <description align="center" color="yellow" colored="false" height="206" resized="false" width="211" x="464" y="437">You will need Text Processing for this</description> <description align="center" color="yellow" colored="false" height="206" resized="false" width="211" x="465" y="222">You will need Operator Toolbox for this</description> </process> </operator> </process>
