Unable to load .csv file from import
User: "ravtal"
New Altair Community Member
Updated by Jocelyn
Hi,
When i try to import .csv file from import data option, after i select the file and click next, Rapidminer gets stuck and does not recover.
Best Regards,
Ravikiran
1 - 10 of 101
    User: "Marco_Boeck"
    Altair Employee
    Hi,
    Would you happen to be able to link the file? Or private message me it?
    Regards,
    Marco
    User: "ravtal"
    OP
    Sent you the file Marco, Thank your for the response.
    User: "Marco_Boeck"
    Altair Employee
    Hi,
    I opened it in RapidMiner Studio 9.5.1, no problems whatsoever. I can import it just fine. See attached screen recording.
    Do you have any errors in the USER/.RapidMiner/rapidminer-studio.log file?
    Regards,
    Marco
    User: "ravtal"
    OP
    Hi,
    In my case the RM gets stuck and does not respond at all. Tried it multiple times.
    Is there any way that I can share my desktop with you?
    This is urgent for me as my University Project is pending :(
    Regards,
    Ravikiran
    User: "Marco_Boeck"
    Altair Employee
    Hi,
    You can use the Read CSV operator. Create a new empty process, add the Read CSV operator, then simply uncheck "first row as names", and select the .csv file from your disk, then run the process.
    Regards,
    Marco
    User: "ravtal"
    OP
    Using Read CSV operator i could get the data set within the process, during this stage how can i  uncheck "first row as names"?
    User: "Marco_Boeck"
    Altair Employee
    Hi,
    Scroll down in the parameters a bit. It's one of the parameters at the bottom.
    Regards,
    Marco
    User: "ravtal"
    OP
    Perfect Thanks
    User: "Ajufo"
    I am having the same issue, I use 9.8 now once i try to import the data, it gets stuck on 'next'. I tried dragging the data into the process, and it got stuck on the timer. What do I do next? P.S I use an ubuntu system.
    User: "Ajufo"
    At this point, I am stuck here
