Unable to load .csv file from import
ravtal
When i try to import .csv file from import data option, after i select the file and click next, Rapidminer gets stuck and does not recover.
Best Regards,
Ravikiran
CSV
Marco_Boeck
Would you happen to be able to link the file? Or private message me it?
Marco
ravtal
Sent you the file Marco, Thank your for the response.
Marco_Boeck
I opened it in RapidMiner Studio 9.5.1, no problems whatsoever. I can import it just fine. See attached screen recording.
Do you have any errors in the USER/.RapidMiner/rapidminer-studio.log file?
Marco
ravtal
In my case the RM gets stuck and does not respond at all. Tried it multiple times.
Is there any way that I can share my desktop with you?
This is urgent for me as my University Project is pending
Ravikiran
Marco_Boeck
You can use the
Read CSV
operator. Create a new empty process, add the
Read CSV
operator, then simply uncheck "first row as names", and select the .csv file from your disk, then run the process.
Marco
ravtal
Using Read CSV operator i could get the data set within the process, during this stage how can i uncheck "first row as names"?
Marco_Boeck
Scroll down in the parameters a bit. It's one of the parameters at the bottom.
Marco
ravtal
Perfect Thanks
Ajufo
I am having the same issue, I use 9.8 now once i try to import the data, it gets stuck on 'next'. I tried dragging the data into the process, and it got stuck on the timer. What do I do next? P.S I use an ubuntu system.
Ajufo
At this point, I am stuck here
