🎉Community Raffle - Win $25
Join and Win
Problem while integrating RapidMiner using Eclipse
User: "Aldi"
New Altair Community Member
Updated by Jocelyn
Hello, I am trying to integrate RapidMiner into my Java Application using Eclipse, I was trying to use the model in my process and extract the results (tree, performance, and table) and show them in my application. But there were a few errors, here are the code and the output.
import java.awt.*;
import java.awt.event.ActionEvent;
import java.awt.event.ActionListener;
import java.awt.event.MouseEvent;
import java.awt.event.MouseListener;
import java.io.File;
import com.rapidminer.RapidMiner;
import com.rapidminer.RepositoryProcessLocation;
import com.rapidminer.gui.RapidMinerGUI;
import com.rapidminer.gui.ToolbarGUIStartupListener;
import com.rapidminer.operator.ExecutionMode;
import com.rapidminer.operator.IOContainer;
import com.rapidminer.operator.IOObject;
import com.rapidminer.tools.PlatformUtilities;
import com.rapidminer.Process;
import com.rapidminer.operator.Operator;
import com.rapidminer.operator.OperatorException;
import com.rapidminer.operator.learner.tree.DecisionTreeLeafCreator;
import com.rapidminer.repository.IOObjectEntry;
import com.rapidminer.repository.ProcessEntry;
import com.rapidminer.repository.Repository;
import com.rapidminer.repository.RepositoryLocation;
import com.rapidminer.repository.RepositoryManager;
import com.rapidminer.tools.XMLException;
import com.rapidminer.tools.plugin.Plugin;
import java.io.IOException;
import java.lang.Object;
import java.nio.file.Paths;
import java.util.Scanner;
import javax.swing.*;
public class GUILauncher extends JFrame implements ActionListener{
public static void main(String args[]) throws Exception {
// System.setProperty(PlatformUtilities.PROPERTY_RAPIDMINER_HOME, Paths.get("").toAbsolutePath().toString());
// RapidMinerGUI.registerStartupListener(new ToolbarGUIStartupListener());
// RapidMinerGUI.main(args);
new GUILauncher();
try {
RapidMiner.setExecutionMode(RapidMiner.ExecutionMode.COMMAND_LINE);
RapidMiner.init();
Plugin.setPluginLocation("D:/RapidMiner Studio/lib/plugins");
Plugin.addAdditionalExtensionDir("D:/RapidMiner Studio/lib/plugins");
Plugin.setInitPlugins(true);
Repository repo = RepositoryManager.getInstance(null).getRepository("Projects");
RepositoryProcessLocation processLocation = new RepositoryProcessLocation(new RepositoryLocation(repo.getLocation(), "Process_25%"));
Process process = processLocation.load(null);
// Operator tree = process.getOperator("Decision Tree");
// tree.setParameter("criterion", "information_gain");
// tree.setParameter("maximal_depth", "6");
// tree.setParameter("apply_pruning", "true");
// tree.setParameter("confidence", "0.5");
// tree.setParameter("apply_prepruning", "true");
// tree.setParameter("minimal_gain", "0.1");
// tree.setParameter("minimal_leaf_size", "2");
// tree.setParameter("minimal_size_for_split", "4");
// tree.setParameter("number_of_prepruning_alternatives", "3");
// IOContainer container = process.run();
// for (int i = 0; i < container.size(); i++) {
// IOObject ioObject = container.getElementAt(i);
// System.out.println(ioObject);
process.run();
} catch (IOException | XMLException ex) {
ex.printStackTrace();
And here is the output:
Dec 28, 2019 5:30:15 PM com.rapidminer.tools.I18N <clinit>
INFO: Set locale to en.
Dec 28, 2019 5:30:15 PM com.rapidminer.tools.PlatformUtilities logInfo
INFO: rapidminer.home is 'D:\IT\5th Semester\Advanced Object-Oriented Programming\Workspace\rapidminer-studio-core\rapidminer-studio-master'.
Dec 28, 2019 5:30:15 PM com.rapidminer.core.license.ProductConstraintManager initialize
INFO: Using OpenSource license manager.
INFO: Initializing license manager.
INFO: Using default license location.
INFO: Registering default product.
Dec 28, 2019 5:30:15 PM com.rapidminer.repository.FileRepositoryProvider load
WARNING: Unknown tag: remoteRepository
Dec 28, 2019 5:30:16 PM com.rapidminer.tools.plugin.Plugin registerPlugins
INFO: Register plugin: PMML
Dec 28, 2019 5:30:16 PM com.rapidminer.tools.plugin.Plugin finalizePluginLoading
SEVERE: Cannot load extension rmx_pmml: Depends on rmx_professional which cannot be found!
Dec 28, 2019 5:30:16 PM com.rapidminer.tools.plugin.Plugin initAll
INFO: Extension rmx_pmml could not be loaded successfully after 4ms.
Dec 28, 2019 5:30:16 PM com.rapidminer.gui.renderer.RendererService registerRenderers
WARNING: Cannot register renderer: java.lang.ClassNotFoundException: com.rapidminer.extension.html5charts.gui.renderer.ExampleSetVisualizationRenderer
at java.net.URLClassLoader.findClass(Unknown Source)
at java.lang.ClassLoader.loadClass(Unknown Source)
at sun.misc.Launcher$AppClassLoader.loadClass(Unknown Source)
at com.rapidminer.tools.plugin.AllPluginsClassLoader.loadClass(AllPluginsClassLoader.java:51)
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Unknown Source)
at com.rapidminer.gui.renderer.RendererService.registerRenderers(RendererService.java:264)
at com.rapidminer.gui.renderer.RendererService.init(RendererService.java:198)
at com.rapidminer.gui.renderer.RendererService.init(RendererService.java:140)
at com.rapidminer.gui.renderer.RendererService.init(RendererService.java:132)
at com.rapidminer.RapidMiner.init(RapidMiner.java:772)
at com.rapidminer.RapidMiner.init(RapidMiner.java:689)
at GUILauncher.main(GUILauncher.java:61)
WARNING: Cannot register renderer: java.lang.ClassNotFoundException: com.rapidminer.extension.html5charts.gui.renderer.AttributeWeightsVisualizationRenderer
WARNING: Cannot register renderer: java.lang.ClassNotFoundException: com.rapidminer.extension.html5charts.gui.renderer.KernelModelWeightsVisualizationRenderer
WARNING: Cannot register renderer: java.lang.ClassNotFoundException: com.rapidminer.extension.html5charts.gui.renderer.NumericalMatrixVisualizationRenderer
Dec 28, 2019 5:30:18 PM com.rapidminer.io.process.XMLImporter addMessage
INFO: <em class="error">The operator class 'concurrency:parallel_decision_tree' is unknown. Possibly you must install a plugin for operators of group 'concurrency'.</em>
Dec 28, 2019 5:30:18 PM com.rapidminer.operator.DummyOperator getExtensionId
WARNING: Cannot connect to update service: java.lang.IllegalStateException: No UpdateManagerFactory registered.
at com.rapidminer.tools.update.internal.UpdateManagerRegistry.get(UpdateManagerRegistry.java:57)
at com.rapidminer.operator.DummyOperator.getExtensionId(DummyOperator.java:130)
at com.rapidminer.operator.DummyOperator.getParameterTypes(DummyOperator.java:99)
at com.rapidminer.operator.Operator.getParameters(Operator.java:1339)
at com.rapidminer.io.process.XMLImporter.parseOperator(XMLImporter.java:625)
at com.rapidminer.io.process.XMLImporter.parseProcess(XMLImporter.java:395)
at com.rapidminer.io.process.XMLImporter.parseOperator(XMLImporter.java:725)
at com.rapidminer.io.process.XMLImporter.parseOperator(XMLImporter.java:465)
at com.rapidminer.io.process.XMLImporter.parseRootOperator(XMLImporter.java:342)
at com.rapidminer.io.process.XMLImporter.parse(XMLImporter.java:305)
at com.rapidminer.io.process.XMLImporter.parse(XMLImporter.java:280)
at com.rapidminer.Process.readProcess(Process.java:1548)
at com.rapidminer.Process.readProcess(Process.java:1530)
at com.rapidminer.Process.<init>(Process.java:294)
at com.rapidminer.RepositoryProcessLocation.load(RepositoryProcessLocation.java:110)
at GUILauncher.main(GUILauncher.java:67)
Dec 28, 2019 5:30:18 PM com.rapidminer.io.process.XMLImporter parseOperator
INFO: The parameter 'criterion' is unknown for operator 'Decision Tree' (" dummy ")."
INFO: The parameter 'maximal_depth' is unknown for operator 'Decision Tree' (" dummy ")."
INFO: The parameter 'apply_pruning' is unknown for operator 'Decision Tree' (" dummy ")."
INFO: The parameter 'confidence' is unknown for operator 'Decision Tree' (" dummy ")."
INFO: The parameter 'apply_prepruning' is unknown for operator 'Decision Tree' (" dummy ")."
INFO: The parameter 'minimal_gain' is unknown for operator 'Decision Tree' (" dummy ")."
INFO: The parameter 'minimal_leaf_size' is unknown for operator 'Decision Tree' (" dummy ")."
INFO: The parameter 'minimal_size_for_split' is unknown for operator 'Decision Tree' (" dummy ")."
INFO: The parameter 'number_of_prepruning_alternatives' is unknown for operator 'Decision Tree' (" dummy ")."
INFO: <em class="error">The input port <var>training set</var> is unknown at operator <var>Decision Tree</var>.</em>
INFO: <em class="error">The output port <var>model</var> is unknown at operator <var>Decision Tree</var>.</em>
Dec 28, 2019 5:30:18 PM com.rapidminer.tools.ResultService init
INFO: No filename given for result file, using stdout for logging results!
Dec 28, 2019 5:30:18 PM com.rapidminer.Process execute
INFO: Process //Projects/Process_25% starts
Exception in thread "main" com.rapidminer.operator.UserError: The dummy operator Decision Tree (replacing concurrency:parallel_decision_tree) cannot be executed.
at com.rapidminer.operator.DummyOperator.doWork(DummyOperator.java:92)
at com.rapidminer.operator.Operator.execute(Operator.java:1031)
at com.rapidminer.operator.execution.SimpleUnitExecutor.execute(SimpleUnitExecutor.java:77)
at com.rapidminer.operator.ExecutionUnit$2.run(ExecutionUnit.java:812)
at com.rapidminer.operator.ExecutionUnit$2.run(ExecutionUnit.java:1)
at java.security.AccessController.doPrivileged(Native Method)
at com.rapidminer.operator.ExecutionUnit.execute(ExecutionUnit.java:807)
at com.rapidminer.operator.OperatorChain.doWork(OperatorChain.java:423)
at com.rapidminer.Process.executeRoot(Process.java:1378)
at com.rapidminer.Process.lambda$7(Process.java:1357)
at com.rapidminer.studio.concurrency.internal.AbstractConcurrencyContext$AdaptedCallable.exec(AbstractConcurrencyContext.java:328)
at java.util.concurrent.ForkJoinTask.doExec(Unknown Source)
at java.util.concurrent.ForkJoinPool$WorkQueue.runTask(Unknown Source)
at java.util.concurrent.ForkJoinPool.runWorker(Unknown Source)
at java.util.concurrent.ForkJoinWorkerThread.run(Unknown Source)
In my understanding, I feel like the last error (Exception in thread "main" com.rapidminer.operator.UserError: The dummy operator Decision Tree (replacing concurrency:parallel_decision_tree) cannot be executed.) seems to be the most severe one? Does anybody know how to fix this error? Or what I did wrong? Thank you for the help, highly appreciated.
Best regards
Aldi
