Altair RISE
Nominate Yourself Now!
Internal Programming Error
User: "Phuong Anh"
Altair Community Member
Updated by Phuong Anh
Hello,
I'm trying to run a non-linear static analysis with Optistruct 2019. However, I always get this error message:
 *** INTERNAL PROGRAMMING ERROR ***
   in file 'malloc_1.c', at location # 723.
   Dyn_array failed allocation for 2.528657e+03 MB
Thank you in advance.
1 - 3 of 31
    User: "QuyNguyenDai"
    Updated by QuyNguyenDai
    It looks like the memory allocation issue. How much RAM do you have?
    User: "Phuong Anh"
    OP
    I have got 16 GB RAM. If I run it on my laptop with also 16 GB, i don't get this error message
    Not really. In your out file, you have ONLY 12420 MB Ram. Have a look at this warning:
      *** WARNING: The amount of allocated memory exceeds available RAM - this may cause significant slowing down of solution progress due to the swapping out memory to the swap file. It is recommended to use out-of-core solution to reduce memory requirements.
