word list
i have a model that has been trained and tested with dataset a. now i am inserting a new dataset into the model and try to get the wordlist output. the problem is if i did not connected the wordlist output from dataset a, the missing attribute problem will appear. but, when i connected the old wordlist data along with the new datasets, i got the wordlist for dataset a and not for the new dataset.. how can i do if i want the wordlist for the new example set?
1 - 4 of
41
The word list is to be seen as a filter, or in other words, new words are ignored as they were not included in the training and are therefore not relevant for the model.
Since your new data will be labeled using the words found during training only, it is therfore kind of logical the same words are returned. If you want to include new words it requires retraining of your data.
did you read up on this? https://community.rapidminer.com/discussion/50278/text-mining-and-the-word-list
BR,
Martin
