word list
i have a model that has been trained and tested with dataset a. now i am inserting a new dataset into the model and try to get the wordlist output. the problem is if i did not connected the wordlist output from dataset a, the missing attribute problem will appear. but, when i connected the old wordlist data along with the new datasets, i got the wordlist for dataset a and not for the new dataset.. how can i do if i want the wordlist for the new example set?
