Logging on the rapidminer server
Just playing around as a newbie with the rapidminer server.
I have some questions on logging.
When I run a process on the sever, I get less logging then when running locally.
For instance :
When I run a process with an exeute script step, I do not see any operator.getLog().log("whatever") entries.
Also when using the Print to Console operator, I do not see any of those results in the Log.
Any thoughts about this ?
I was also wondering about how to configure a relative path in the process attrbitue (logfile).
And then specifically, relative to the process definition location.
For instance :
1 - 9 of
91
Hi @Artm ,
did you try to increase the severity level? Like
operator.getLog().log("whatever",5)
Best,
Martin
@mschmitz, I did not use the additional parameter yet. But I did set the log level to all in the process.
@mschmitz, I tried also with the ,5 (warning) addition, but process on server just mentions :
Dec 18, 2019 2:39:09 PM com.rapidminer.execution.jobcontainer.execution.SimpleExecutor
INFO: Execution of job '6d62d0ec-bc43-4a46-af9f-3cd389b9cab0' finished successfully.
Locally it (only) says :
Dec 18, 2019 3:40:15 PM WARNING: whatever
Hi @Artm ,
Which log file did you check - server.log?
If you run a process on RapidMiner Server it is usually executed in a JobContainer on a JobAgent.
You should be able to see the same log output compared to RapidMiner Studio when you take a look at the process execution log which can be found in the RapidMiner Server Webinterface => Executions.
Happy Mining,
Edin
Hi @Edin, I in fact did look only at the process execution log.
Locally
Locally
Dec 20, 2019 3:42:12 PM INFO: Process starts
Dec 20, 2019 3:42:12 PM WARNING: whatever
Dec 20, 2019 3:42:12 PM INFO: Saving results.
Dec 20, 2019 3:42:12 PM INFO: Process finished successfully after 0 s
Server
Server
Dec 20, 2019 2:42:49 PM com.rapidminer.tools.ResultService init
INFO: No filename given for result file, using stdout for logging results!
Dec 20, 2019 2:42:49 PM com.rapidminer.execution.jobcontainer.execution.ExecutionProcessListener processStarts
INFO: Execution of process started
Dec 20, 2019 2:42:49 PM com.rapidminer.Process execute
INFO: Process //_LOCAL/home/artm/processes/dummy starts
Dec 20, 2019 2:42:49 PM com.rapidminer.execution.jobcontainer.execution.ExecutionProcessListener processStartedOperator
INFO: Started operator : Process
INFO: Started operator : Execute Script
Dec 20, 2019 2:42:49 PM com.rapidminer.execution.jobcontainer.execution.ExecutionProcessListener processFinishedOperator
INFO: Finished operator : Execute Script
INFO: Finished operator : Process
INFO: Process //_LOCAL/home/artm/processes/dummy finished successfully after 0 s
Dec 20, 2019 2:42:49 PM com.rapidminer.execution.jobcontainer.execution.ExecutionProcessListener processEnded
INFO: Execution of process stopped
Dec 20, 2019 2:42:49 PM com.rapidminer.execution.jobcontainer.execution.SimpleExecutor
INFO: Execution of job 'df93adee-5e98-41c5-aaf9-50b27cf6b72e' finished successfully.
Hi @Artm ,
that is very strange. I get the same output in all execution environments (logverbosity on Process level has been kept to "init").
Can you post your process so we can check that?
Happy Mining,
Edin
Studio:
Server:
JobAgent:
1 - 1 of
11
Hi Artm,
have you tried using
operator.getLogger().info("foo")
This will re-use the logger of the process instead of creating a new one.
Cheers
Marcel
