ERROR 6538 - Sliding Contact with interference (negative clearance)
covadonga
covadonga Altair Community Member
edited October 2020 in Community Q&A
I am running a model in which the contact has interference. as part of the installation process one part is pushed along the second one, therefore there is a frictional contact between them. This is the error message I get:
*** ERROR # 6538 ***
 Finite sliding (TRACK=FINITE) CONTACT 1 is not compatible with CLEARANCE
 in LGDISP analysis. CONTPRM,LSLDCLR,YES can be set with caution to bypass the
 restriction.
I am working with HW2019 and the option  LSLDCLR is not available. is there an alternative way to solve this issue?
Any insights?
Welcome!
Answers
  • Adriano_Koga
    Adriano_Koga
    Altair Employee
    edited July 2020
    Your model really needs large displacements? If not, you could switch off LGDISP.
    Even though HM doesnt support it, you can add it using unsupported cards:
  • covadonga
    edited July 2020
    Thanks Adriano,
    LSLDCLR did not avoid the issue. I need large displacmentes, the relative motion between parts is significant, it is part of the installation.
    I keep getting the error 6538 as soon as I specify S2S or N2S for the contact discretization, when I leave it by default no error message shows.
    Leaving it by default is however not the solution , since the contact elements of the part do not get update despite the relative motion.
    The Initial contact elements are the only ones working during the simulation.
    Any ideas? Also, where can I find more infor about error 6538?
    Kind regards,
  • Adriano_Koga
    Adriano_Koga
    Altair Employee
    edited July 2020
    Are you sure you've activate it correctly?
    Please try running the attached model. I've added a 5mm interference, with FINITE Sliding and LGDISP, rotating 1rad the pin.
  • Adriano_Koga
    Adriano_Koga
    Altair Employee
    edited July 2020
    Also as an alternative, you can specify a GPAD in contact property (PCONT).
    This will have the same behavior.
  • covadonga
    edited July 2020
    Thank you Adriano,
    Your answers were really helpful, How would you make the model slide axially?
    When the contact is defined via PCONT, the padding paramenter GPAD is set to 5, why so? was it required to ease convergency? It seems to be incompatible with the negative clearance (press fit) Please find attached two modified models, in which I force the cylinder to slide axially. Dummy8 will not run due to the negative clearance.
    Additionally I observed something awkward and I would like to have your opinion, after downloading the exampled I requested the output contact information, CONTF, and all of a sudden the error 6538 showed. I did download the .fem again, requested the contact output info and this time I did get results. What could be causing the error 6538 come out? Is this random?
  • Adriano_Koga
    Adriano_Koga
    Altair Employee
    edited July 2020
    the 5 stand for 5mm of clearance in my example.
    If you use Clearance, it should be -5.0mm.
    Using GPAD, 5.0mm.
    For sliding axially i would add a SPC in axial direction with a predefined enforced displacement value.
  • covadonga
    edited July 2020
    Thank you Adriano,
    Both models work well, however the contact pattern is not quite uniform only few nodes get paired actually (contact status). Intuitively due to the press fit the surfaces are in contact. Have you seen something like this before? How ccould I prove my model?
    I have read the following about the control card GAPPRM, HMGAPST:
    For correct visualization of their open/closed status in HyperMesh, this file needs to be imported before running the gap status command file, <my_job>.HM.gapstat.cmf.
    Could you give some more detail about how to properly visualize contact status?
    Best regards
  • Adriano_Koga
    Adriano_Koga
    Altair Employee
    edited July 2020
    Contact Status is visualized by CONTF output in OptiStruct, and it will show in HyperView as contact status.
    If you use clearance, this should be more or less uniform
    But you could also use some smoothening (SMOOTH in contact) to get a smoother contact distribution, if that's what you want.
  • covadonga
    edited July 2020
    Thanks Adriano,
    What would be the pros and cons of using contact smoothing? Are there ay special precautions when using contact smoothing?
  • covadonga
    edited July 2020
    Hi again, depending on which of member of the contact pair the smoothing is applied, different normal and tangent forces are obtained, why so?
Welcome!
Welcome!
