🎉Community Raffle - Win $25
Join and Win
ERROR 6538 - Sliding Contact with interference (negative clearance)
User: "covadonga"
Altair Community Member
Updated by covadonga
I am running a model in which the contact has interference. as part of the installation process one part is pushed along the second one, therefore there is a frictional contact between them. This is the error message I get:
*** ERROR # 6538 ***
 Finite sliding (TRACK=FINITE) CONTACT 1 is not compatible with CLEARANCE
 in LGDISP analysis. CONTPRM,LSLDCLR,YES can be set with caution to bypass the
 restriction.
I am working with HW2019 and the option  LSLDCLR is not available. is there an alternative way to solve this issue?
Any insights?
