Community & Support
Learn
Marketplace
Discussions
Categories
Discussions
General
Platform
Academic
Partner
Regional
User Groups
Documentation
Events
Altair Exchange
Share or Download Projects
Resources
News & Instructions
Programs
YouTube
Employee Resources
This tab can be seen by employees only. Please do not share these resources externally.
Groups
Join a User Group
Support
Altair RISE
Nominate Yourself Now!
Home
Discussions
Community Q&A
Run a simple SVM model
ReJay
I run the decision model and knn model using the same layout,but the SVM model fail.
AI Studio
SVMs
Auto Model
Accepted answers
All comments
ReJay
It shows me that rapidminer (LibSVM) cannot handle polynominal attributes.
varunm1
Hello
@ReJay
SVM algorithms cannot work on attributes with Nominal (Categorical) variables. They only work on numerical data. In case of nominal, you can convert them to numerical using "nominal to numerical" and run SVM. I am not sure about your data properties so I cannot comment if it is a good idea to convert nominal attributes to numerical.
Hope this helps.
Regards
Varun
ReJay
Thank you for your answering(I don't know how to @ you :'( )
My data is number.
I read it on hive. If the reason is the name of table?
varunm1
Are all your fields numeric (numbers)? I think you might have some categorical variables (nominal attributes) n your dataset which is causing this issue. If you want us to check please follow the below steps.
Please export your process (.rmp file) using FILE --> Export Process from rapidminer and attach your dataset file (Excel, CSV etc.) and the exported process in this thread? It will help us to check and inform more details.
ReJay
Ok, you are so kind! thank you for help again.
svm.rmp
default of credit card clients22.xls
varunm1
Hello
@ReJay
Thanks for attaching the files. I checked your data in RM and can confirm that all columns are numbers. The new error I saw is related to the label (output) column Y. This iY column is also read as a numeric value. As you are trying to do a classification problem (based on SVM kernel type) I added numerical to nominal operator that converts the numerical Y column into nominal. Now the process works.
Import the attached process into your RM by using FILE --> Import process and attach your dataset and run it.
Hope this helps. Let us know if you need more information.
SVM_New.rmp
ReJay
I change "Y" to "y" in Set Role when it send error. But the NtP send error.
varunm1
If it is already nominal you don't need to change it using numeric to nominal. Just disable the nominal to numeric and try running it. In my case, it is read as numeric so I changed it to nominal.
Quick Links
All Categories
Recent Discussions
Activity
Unanswered
日本語 (Japanese)
한국어(Korean)
Groups
