Loop operator does not output Generated attributes for later use
Is there a workaround for this? I am using a Loop Parameter operator to generate a bunch of moving averages. Later on the same process I would like to select some of those newly created attributes but they are never available from the select attributes operator window. The only way for me to see them is to export the dataset to an excel file and then import it again as a new file. Then the attributes appear as normal.
