🎉Community Raffle - Win $25
Join and Win
Evaluation of Classification models
User: "Muhammed_Fatih_"
New Altair Community Member
Updated by Jocelyn
Hello together,
is there a possibility within RapidMiner to parallelly train and test selected classification models and subsequently return the best performance result of the respective classification model? The goal of my research is to evaluate the behaviour of classification models with regard to the determination of the best performance.
Thank you for your answers!
Best regards,
Fatih
1 - 3 of 31
    User: "sgenzer"
    Altair Employee
    Accepted Answer
    Hello @Muhammed_Fatih_ absolutely. It's called "Auto Model" and it's at the top of your screen. :smile:
    OP
    Hi @sgenzer
    thank you for your answer which was very helpful :) Is there also the possibility to execute ROC Comparison with Cross-Validation?
    User: "lionelderkrikor"
    Hi @Muhammed_Fatih_,
    1. Inside AutoModel, by default, the model(s) is (are) not validated by a cross-validation, but by a multi - hold-out-set validation.
    See the documentation on the "results" screen :
    You can also inspect the generated process(es) after executing AutoModel to inspect them and understand exactly how is (are)
    calculated the performance of the model(s).
    2. If you want to obtain the comparaison of ROC curves with a cross-validation, you can use the Compare ROCs operator.
    Simply put the models you want to benchmark inside this operator.
    Hope this helps,
    Regards,
    Lionel
