🎉Community Raffle - Win $25
Join and Win
[Solved] Thermal Cooling Simulation with Oil
User: "Junta_20361"
New Altair Community Member
Updated by Junta_20361
Hi everyone,
I need to do a thermal cooling simulation for a transformer.
The simple model is shown as below image:
Normally, we run the simulation with water/air.
However, the fluid used in this case is OIL.
So can AcuSolve make the simulation with Oil?
If yes, Is there any special setting has to be made?
Furthermore, how should i define the interface b/w air and Oil (or water) in this case?
Should i use multi-phase (level set/ Euler) or free surface or any other treatment?
Thank you very much!
