🎉Community Raffle - Win $25
Join and Win
[Solved] Thermal Cooling Simulation with Oil
User: "Junta_20361"
New Altair Community Member
Updated by Junta_20361
Hi everyone,
I need to do a thermal cooling simulation for a transformer.
The simple model is shown as below image:
Normally, we run the simulation with water/air.
However, the fluid used in this case is OIL.
So can AcuSolve make the simulation with Oil?
If yes, Is there any special setting has to be made?
Furthermore, how should i define the interface b/w air and Oil (or water) in this case?
Should i use multi-phase (level set/ Euler) or free surface or any other treatment?
Thank you very much!
1 - 6 of 61
    User: "ydigit"
    Altair Employee
    Updated by ydigit
    Yes this is definitely possible with AcuSolve.
    Adding a  multiphase approach would increase the run time and also force you to run transient.
    The easiest 'trick' would be to also model the air volume in CAD and then define a new 'solid' material with properties of air. This 'solid' air will take into account heat transfer between oil and air.  You could also run steady state with this approach.
    User: "acupro"
    Altair Employee
    Updated by acupro
    Another option would be not to model the air above at all, just assume some convective heat transfer using a convective heat transfer coefficient with a corresponding reference temperature on the external surfaces of the oil/housing/transformer.
    User: "Junta_20361"
    OP
    Hi Ydigit and Acupro,
    Thanks a lot for your answer.
    I will try with your ideas.
    Thanks again :D/emoticons/default_biggrin.png' srcset='/emoticons/biggrin@2x.png 2x' title=':D' width='20' />
    User: "Junta_20361"
    OP
    hi Ydigit and acupro,
    I have another questions regarding to your solutions,
    What is the type of the 'interface' between Oil and Air if i create a solid-air or assign convective HTC?
    Should it be 'slip'?
    Thank you!
    User: "acupro"
    Altair Employee
    Updated by acupro
    If you're just doing single-phase flow, I would probably use slip on the surface attached to the fluid volume.  Then you still may need to add Element Boundary Condition of type heat-flux to assign the convective HTC.
    User: "Junta_20361"
    OP
    Thanks Acupro,
    I got it!
