Altair RISE
Nominate Yourself Now!
[Solved] Thermal Cooling Simulation with Oil
Junta_20361User: "Junta_20361"
New Altair Community Member
Updated by Junta_20361
Hi everyone,
I need to do a thermal cooling simulation for a transformer.
The simple model is shown as below image:
Normally, we run the simulation with water/air.
However, the fluid used in this case is OIL.
So can AcuSolve make the simulation with Oil?
If yes, Is there any special setting has to be made?
Furthermore, how should i define the interface b/w air and Oil (or water) in this case?
Should i use multi-phase (level set/ Euler) or free surface or any other treatment?
Thank you very much!
1 - 7 of 71
    ydigitUser: "ydigit"
    Altair Employee
    Updated by ydigit
    Yes this is definitely possible with AcuSolve.
    Adding a  multiphase approach would increase the run time and also force you to run transient.
    The easiest 'trick' would be to also model the air volume in CAD and then define a new 'solid' material with properties of air. This 'solid' air will take into account heat transfer between oil and air.  You could also run steady state with this approach.
    acuproUser: "acupro"
    Altair Employee
    Updated by acupro
    Another option would be not to model the air above at all, just assume some convective heat transfer using a convective heat transfer coefficient with a corresponding reference temperature on the external surfaces of the oil/housing/transformer.
    OP
    Hi Ydigit and Acupro,
    Thanks a lot for your answer.
    I will try with your ideas.
    Thanks again :D/emoticons/default_biggrin.png' srcset='/emoticons/biggrin@2x.png 2x' title=':D' width='20' />
    OP
    hi Ydigit and acupro,
    I have another questions regarding to your solutions,
    What is the type of the 'interface' between Oil and Air if i create a solid-air or assign convective HTC?
    Should it be 'slip'?
    Thank you!
    Altair Employee
    Updated by acupro
    If you're just doing single-phase flow, I would probably use slip on the surface attached to the fluid volume.  Then you still may need to add Element Boundary Condition of type heat-flux to assign the convective HTC.
    OP
    Thanks Acupro,
    I got it!
    Hi there,
    Looking at the shared picture, you don't need to go into the complexities of to model the mineral oil free surface because most of the natural convective cooling effect will be happening at the metallic housing walls (there are 5 face against 1, plus natural convection on vertical walls is bigger than in horizontal walls). At least that you imposed a forced convective movement of the air at the oil free surface, I do not see any issue if you just use a constant heat transfer coefficient of 2 W/((m^2)*K) at the free surface.
    Hope this comment helps!
