Executing file on Mac
Has something changed with the execute programs operator?
<?xml version="1.0" encoding="UTF-8"?><process version="9.4.001"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="9.4.001" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="text:create_document" compatibility="8.2.000" expanded="true" height="68" name="generate query" width="90" x="45" y="85"> <parameter key="text" value="aws athena start-query-execution --query-string "select * from table where col0 like 'number';" --result-configuration "OutputLocation=s3://" "/> <parameter key="add label" value="false"/> <parameter key="label_type" value="nominal"/> </operator> <operator activated="true" class="text:write_document" compatibility="8.2.000" expanded="true" height="82" name="overwrite query" width="90" x="179" y="85"> <parameter key="file" value="/Users/robinmeisel/Dropbox/psyscore/master.sh"/> <parameter key="overwrite" value="true"/> <parameter key="encoding" value="SYSTEM"/> </operator> <operator activated="true" class="productivity:execute_program" compatibility="9.4.001" expanded="true" height="124" name="Execute Program" width="90" x="313" y="85"> <parameter key="command" value="chmod +x master.sh"/> <parameter key="log_stdout" value="true"/> <parameter key="log_stderr" value="false"/> <parameter key="working_directory" value="/Users/execute"/> <list key="env_variables"/> </operator> <operator activated="true" class="productivity:execute_program" compatibility="9.4.001" expanded="true" height="124" name="Execute Program (2)" width="90" x="447" y="85"> <parameter key="command" value="./master.sh"/> <parameter key="log_stdout" value="true"/> <parameter key="log_stderr" value="true"/> <parameter key="working_directory" value="/Users/execute"/> <list key="env_variables"/> </operator> <connect from_op="generate query" from_port="output" to_op="overwrite query" to_port="document"/> <connect from_op="overwrite query" from_port="document" to_op="Execute Program" to_port="through 1"/> <connect from_op="Execute Program" from_port="out" to_op="Execute Program (2)" to_port="through 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> </process> </operator> </process>I am now getting this error where the process used to work perfectly. Any ideas?
