Hi,
I would like RapidMiner to count the cells of my exa with a value >= 0. I tried the generate aggregation operator wit the numeric value filter (condition >=0) and word count. Unfortunately RapidMiner still counts every cell of my exa inluding 0 values. Do I need another filter?
Thanks!
Regards
I'm not sure to understand. You set condition >=0 and you did not want cell including 0 values....
To my knowledge, ">=0" means "0" OR ">0".
Could you, with an example, precise what you want to obtain and ideally
share your data in order we can run your process...
Thanks,
Regards,
Lionel
