🎉Community Raffle - Win $25
Join and Win
Generate weights applied to examples
User: "je23"
New Altair Community Member
Updated by Jocelyn
Hi, Im very new to data science in general and Rapid Miner.  I have a process where I have used the Generate weight operator and obtained a result.  Now I want to apply that weight to the example attributes.
Example:
Row No   Attrib 1    Weight   Attrib 2
1              Label          .69     Number
I want the weight to be applied to Attribute 2 so the Number is the weighted data.
Thank you
1 - 2 of 21
    User: "tftemme"
    Accepted Answer
    Hi @je23
    You can use the Generate Attribute operator to create a new attribute which is just the product of the Weight and the Attrib 2 attributes.
    Be aware that you need to set the name of attributes in squared brackets if they have blanks in their names.
    Best regards,
    Fabian
    User: "je23"
    OP
    Thank you, that worked
