Altair RISE
Nominate Yourself Now!
Home
Discussions
Community Q&A
cannot run process due to debug mode problem
mimienara
my rapid miner cannot run the process even after the apps told me to on the debug mode but it is shown process failed. so how can i fix my rapidminer? thankyou
AI Studio
Bug Report
Accepted answers
varunm1
Hello
@mimienara
Did you try checking the log window (View --> Show Panel --> Log), to see the error you were getting?
Can you post the error message in log here?
All comments
varunm1
Hello
@mimienara
mimienara
thankyou for your fast reply. there is no any bug problem but my rapid miner still have an issue not showing the result after run. how to fix it?
my laptop specification is AMD A9-9425 RADEON R5, 5 COMPUTE CORES 2C+3G 3.10GHz RAM: 4GB, x64 based processor.
is it the problem is my laptop?
varunm1
Are you using Java 8 version and are you working on 64 bit OS with 64-bit rapidminer version? I just boosted your profile, you can also post images of the result area that is not showing up.
Thanks
mimienara
this the result after i click run process. i dont know how to check whether i using java 8 or not, and im working on 64bit os with 64 bit rapidminer version.
varunm1
I saw this issue on an earlier thread. I am connecting relevant people here
@sgenzer
@Marco_Boeck
if they could provide any insights on this.
https://community.rapidminer.com/discussion/comment/61285#Comment_61285
To check if you are using Java 8 or not in the control panel as shown in below image highlighted portion.
mimienara
after i check my laptop, im not using any java 8. how can i do it?
varunm1
Then, you should download Java 8 from below thread based on your operating system
https://www.oracle.com/technetwork/java/javase/downloads/jdk8-downloads-2133151.html
Then, you can uninstall current java version and install this java 8 version in your laptop.
mimienara
after i install the java 8 apps? what steps that i need to do and how to check my old version java ?
varunm1
You can check the existing version in Control panel as I said earlier. You can restart you PC and rapidminer to see if its working fine now. I think it will find java automatically from "path" in "environmental variables".
Marco_Boeck
Hi,
Try clicking "View -> Restore default view" in the top menu bar when in that state. It looks like your results view became broken.
Regards,
Marco
mimienara
Thankyou for helping and give me ways how to fix my rapid miner. I follow all your instructions given and finally my rapidminer can run. Im so happy and thankyouuu
Quick Links
All Categories
Recent Discussions
Activity
Unanswered
日本語 (Japanese)
한국어(Korean)
Groups
