Question about hertz-mindlin with bonding?
Raheem Sterling_22160
Raheem Sterling_22160 Altair Community Member
edited August 2023 in Community Q&A
Hi,
I want to calculate HM force after bond broken which was different with HM with bonding(bond force and HM force were calculate together). So I stored the initial normal physical overlap with contact custom property at the bond creation time, but I am confuesd when I dealt with tangential overlap, I am not sure if the tangential overlap changes or not in the calculation of bond force without sliding.
Answers
  • Stefan Pantaleev_21979
    Altair Employee
    edited August 2023
    Hi Raheem,
    Both the tangential and normal overlaps can change as the bond deforms. After the bond breaks the bond forces should be zero and the contact force should become the HM force.
    Best regards,
    Stefan
Welcome!
Welcome!
