🎉Community Raffle - Win $25
Join and Win
FE-SAFE ODB results loaded to Hyperview -> N/A results
User: "rem_rem"
New Altair Community Member
Updated by rem_rem
hi,
I would like to know if there is a trick to visualize fatigue results of an .odb file generated by FE-Safe.
Because when I load the file to Hyperview, all the results generated are N/A ( Safety Factor , S/UTS etc) but exists when I open the same file into Abaqus Viewer for example.
For info, additional fatigue step results is created by FE-SAFE after a required .odb loadcase results.
Thank you.
1 - 3 of 31
    User: "Altair Forum User"
    Altair Employee
    Updated by Altair Forum User
    Hi rem_rem,
    Which version of HyperWorks you are using? .ODB file is supported in 2017.1 version.
    Thank you
    User: "rem_rem"
    OP
    Updated by rem_rem
    Hi.
    i use Hyperview 2017.2.
    I can open and  view 'usual' results  ( S, U<NT etc...) from .ODB file for whatever version of my abaqus solving. ( 2016, 14.X. etc).
    It just seems that i cant visualize the 'step' of FE-Safe which contains Safety factor and other exported results..
    Thanks
    User: "rem_rem"
    OP
    Updated by rem_rem
    Well I found a solution,
    In the contour Panel, i ticked 'Use corner data' and results on scale were revealed.
    If it can help someone, you're welcome
    Rem
