FE-SAFE ODB results loaded to Hyperview -> N/A results
hi,
I would like to know if there is a trick to visualize fatigue results of an .odb file generated by FE-Safe.
Because when I load the file to Hyperview, all the results generated are N/A ( Safety Factor , S/UTS etc) but exists when I open the same file into Abaqus Viewer for example.
For info, additional fatigue step results is created by FE-SAFE after a required .odb loadcase results.
Thank you.
Hi rem_rem,
Which version of HyperWorks you are using? .ODB file is supported in 2017.1 version.
Thank you
0 -
Hi.
i use Hyperview 2017.2.
I can open and view 'usual' results ( S, U<NT etc...) from .ODB file for whatever version of my abaqus solving. ( 2016, 14.X. etc).
It just seems that i cant visualize the 'step' of FE-Safe which contains Safety factor and other exported results..
Thanks
0 -
Well I found a solution,
In the contour Panel, i ticked 'Use corner data' and results on scale were revealed.
If it can help someone, you're welcome
Rem
