🎉Community Raffle - Win $25
Join and Win
FE-SAFE ODB results loaded to Hyperview -> N/A results
rem_remUser: "rem_rem"
New Altair Community Member
Updated by rem_rem
hi,
I would like to know if there is a trick to visualize fatigue results of an .odb file generated by FE-Safe.
Because when I load the file to Hyperview, all the results generated are N/A ( Safety Factor , S/UTS etc) but exists when I open the same file into Abaqus Viewer for example.
For info, additional fatigue step results is created by FE-SAFE after a required .odb loadcase results.
Thank you.
1 - 3 of 31
