Home
Discussions
Community Q&A
n-Grams with a length of 3-6
Kathi
Hi everyone,
I am currently using the n-Grams operator. If I set the length to 6, all n-Grams will be displayed with a word count of 1-6. I just want to see the n-Grams with a length of 3-6 words. Is that possible?
Thanks!
AI Studio
Accepted answers
lionelderkrikor
Hi
@Kathi
Nice challenge !
Yes, it is possible. You have to duplicate your text processing using :
for the first :
max length = 6
for the second :
max length = 2
then
Transpose
the 2 resulting example sets
then use a
Set Minus
operator to keep only the attribute with
3< max length <6
finally (re)
Transpose
the final example set.
The process is in attached file.
Regards,
Lionel
Set_minus_n_grams.rmp
All comments
kayman
Use filter tokens by content, select match and use a regex like ^.*?_.*?_.*
This will filter on all n-grams having at least 2 underscores, so matching 3 words or more
lionelderkrikor
Hi
@Kathi
Nice challenge !
for the first :
max length = 6
for the second :
max length = 2
then
Transpose
then use a
Set Minus
3< max length <6
finally (re)
Transpose
Regards,
Lionel
Kathi
Hi,
I first tried the set-minus-process, it's working and looks fantastic! Thank you both!
Regards,
Kathi
Quick Links
All Categories
Recent Discussions
Activity
Unanswered
日本語 (Japanese)
한국어(Korean)
