🎉Community Raffle - Win $25
Join and Win
Probability of prediction column in a binary classification problem.
SA_HUser: "SA_H"
New Altair Community Member
Updated by Jocelyn
Using the (apply model operator) in the binary classification problem, the results exported in the form of the prediction column and confidences of being 0 or 1. Please I am wondering if there is an operator that can export  the probability (range from 0-1 such as 0, 0.1, 0.2, ...) or scores indicating the likelihood that a label comes from a particular class (0 or 1).
1 - 3 of 31
    varunm1User: "varunm1"
    Hello @summer_helmi
    Sorry, I am confused can you please explain in detail. The prediction confidences are similar to  probabilities, that shows the confidences of a particular class for a particular observation between 0 and 1. If the algorithm is really confident then it will assign 1 to related label (class).
    Hi,
    confidences are not probabilities, but correlated. To get something way closer to propabilities we recommend to use Rescale Confidences (Logistic), which uses Platt Scaling.
    Best,
    Martin
    SA_HUser: "SA_H"
    OP
    Updated by SA_H
    Thank you,
