🎉Community Raffle - Win $25
Join and Win
Concrete material parameters
User: "gopal_rathore"
Altair Community Member
Updated by gopal_rathore
Hi @George P Johnson
@Prakash Pagadala
I am trying to get the material parameters of the MAT_24 concrete through experimental testing. I am not able to get details of the parameters even through theory manual and thus want to understand two things:
1) Complete definition of notations like: ft,fb,fo, f2 , S0, Ht etc.
Also for tensile are we looking for split tensile testing data or fleuxral tensile testing data
2) If any reference for material testing for these parameters
1 - 4 of 41
    User: "Altair Forum User"
    Altair Employee
    Updated by Altair Forum User
    Hi Gopal,
    For concrete materials, failure is much more rapid in tension compared to tension. Higher compressive strength makes tha ft/fc ratio small. The same goes with rest of the parameters.
    I will check the rest and will get back to you.
    OP
    Hi @Prakash Pagadala
    I wanted to know how to obtain these parameters through physical uniaxial compression, split tensile testing and flexural tensile test methods. Do we have any numerical relations to derive these parameters. Currently I am able to get Fc, Poisson ratio, Youngs Modulus only with reference to IS:456 standard
    Also do you have document stating about  what strain rate range is observed  for metals in vehicle crash scenarios? As I am planning physical testing for metals also at different strain rates
    OP
    Any update on this?
    Altair Employee
    Hi Gopal,
    I will share a couple of PDFs with you soon for LAW 24 and validation of the same.
