How can i do to change integer values in more than 1 attribute?
1 - 5 of
51
Hello @cdaponte
You don't need five generate attribute operators, you can create all of them in one. Here is the XML code for you to check.
<?xml version="1.0" encoding="UTF-8"?><process version="9.4.001"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="6.0.002" expanded="true" name="Process" origin="GENERATED_TUTORIAL"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="9.4.001" expanded="true" height="68" name="Retrieve Polynomial" width="90" x="112" y="85"> <parameter key="repository_entry" value="//Samples/data/Polynomial"/> </operator> <operator activated="true" breakpoints="before,after" class="generate_attributes" compatibility="9.4.001" expanded="true" height="82" name="Generate Attributes" width="90" x="313" y="85"> <list key="function_descriptions"> <parameter key="a1" value="a1*1000"/> <parameter key="a2" value="a2*1000"/> <parameter key="a3" value="a3*1000"/> <parameter key="a4" value="a4*1000"/> <parameter key="a5" value="a5*1000"/> </list> <parameter key="keep_all" value="false"/> </operator> <connect from_op="Retrieve Polynomial" from_port="output" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator> </process>
Hope this helps
haha yes is cooler with a loop @IngoRM
Thanks!
Thanks!
1 - 1 of
11
And you can place the Generate Attributes inside of a Loop Attributes if you want to automate the multiplication for all columns (I guess with 5 you can also use 5 Generate Attributes, but, you know, it's cooler with a loop
If I good understand, you will need of Generate Attributes operator for this task.
The name of the generated attribute has to be strictly the same that the name of the original attribute.
Hope this helps,
Regards,
Lionel
